fuel injector problems
Old Mar 5, 2005 | 11:48 AM
johnm1019's Avatar
Default fuel injector problems
accidentally posted in B6 forum but heres link to thread, really could use some help with this one....<ul><li><a href="https://forums.audiworld.com/a4gen2/threads/93534.phtml#788212">https://forums.audiworld.com/a4gen2/threads/93534.phtml#788212</a></li></ul>
Old Mar 5, 2005 | 12:04 PM
Phil type 951's Avatar
Default I dont understand what you are asking
for a non-dbw a4 you should have red top injectors not blue ones.
you dont need to grind or use any adapters, its plug and play.
Avant_AK04's Avatar
New Member
Default Re: fuel injector problems
Had 310cc installed and they were higer than stock, need 10mm spacer(used 1/2" bolt grind to size) and longer bolts to hold them down.
Old Mar 5, 2005 | 12:18 PM
johnm1019's Avatar
Default Re: I dont understand what you are asking
that answers my question :-\
looks like they sent me the wrong injectors... i told them to inlude a packing list but they said they checked it 3 times and it was fine :-\
guess i'll get on the phone with apr tommorow to get the right injectors
Can i run the car on stock injectors to get the car home?
Thanks
Old Mar 5, 2005 | 12:26 PM
Default I dont know how the car will react to sIII program and stock injectors
If you MUST drive it try it but I would not boost at all. I would rather see you leave the car parked till you have the rigth injectors.
Old Mar 5, 2005 | 12:35 PM
johnm1019's Avatar
Default Re: I dont know how the car will react to sIII program and stock injectors
ok, im pretty sure i can leave it here at the shop..... thanks for your quick advice.
this is more of a what if than anything else, but could i use the blue injectors with a spacer?
Old Mar 5, 2005 | 12:48 PM
Default I dont think that would be a very good idea.
the ecu programing tells the injectors to spray an amount of fuel based on a % of maximum flow. the blue injectors are stock TT injectors used for dbw stage III kits. the red ones for the NDBW kits are oem turbo porsche injectors and flow much more fuel then the tt injectors. the tt injectors would always be spraying less fuel then the car needs and expects.
you can buy the correct injectors online from epd and have them shipped overnight for under 300$ then return the tt injectors to apr and get a credit for about 400.
PILL PUSHER
21
Aug 6, 2007 01:05 PM
virtuapete
Oct 7, 2004 01:05 AM
AjaxAudi
Nov 16, 2003 07:27 PM
Barnstormer
Oct 16, 2003 03:43 PM
jquattro
16
Dec 12, 2002 07:59 AM
