Timing Belt Problem?
Old 06-15-2009, 04:07 PM
Daltron's Avatar
Default Timing Belt Problem?
So I fixed my overheating problem and ran into another. While I was test driving down the highway my car all of the sudden lost power and start to putt. When I let of the gas pedel and slowing pushed it in the car ran fine. When I push the gas in to go it does not go nearly as fast as before. It felt like the car was trying to go but did not have enough power. I stopped to check out the engine and nothing appeared to be wrong. When I went again and gave it gas it putted along then I let off and it back fired out the exhaust only once not loud. I took it easy going home and only pushed the gas in slightly and was able to make it. But I am stumped on what it could be.
Is there an easy way to take the timing belt off and re set everything? I looked with no luck.
Could it be anything with the throttle?
What else could it be?
Old 06-15-2009, 04:46 PM
Tech Guru
4Driver4's Avatar
Codes?
Old 06-15-2009, 06:56 PM
Daltron's Avatar
No codes...Check engine never came on.
Old 06-15-2009, 06:57 PM
Keeper of the Cash
Nate (ETKA+Scumbag)'s Avatar
But did you actually check? Codes can appear with or without the MIL.
Old 06-15-2009, 07:22 PM
Daltron's Avatar
No I took the car home and took it apart. My timing belt is off. But i didnt know if it could be a fuel filter/timingbelt/throttle.
Im new to doing my own work and bought a haynes book to walk me through.
Daltron's Avatar
Well at least thats what I think is off.
jikons
9
04-26-2020 03:42 PM
dman413
01-11-2006 06:15 PM
sidespar
03-15-2004 12:17 AM
Fat_Joe
07-08-2002 05:04 PM
plexxx
12-11-2001 09:51 AM
Quick Reply: Timing Belt Problem?
