Getting closer to a solution to the boost problem
Old Oct 2, 2002 | 08:13 PM
kk_1.8t's Avatar
New Member
Default Getting closer to a solution to the boost problem
<center><img src="http://pictureposter.audiworld.com/26867/boost_log_sm.jpg"></center><p>I resetted my ECU like Audi2ptzero said (BTW thanks) So I finally feel the extra boost from the Xchip. But still not as it was when it was first put in.
Here's a Graph of my boost log of Actual vs Requested. I know I should get at least 20psi with this chip. I max at 18psi. How much difference in feeling is the 2psi?! Doesn't seem to be a vaccum leak cause I'm still getting about 18psi? Or is it??
Advice needed. Thanks guys
Here's a graph of the entire time period:
http://pictureposter.audiworld.com/26867/boost_log.jpg
Old Oct 2, 2002 | 09:02 PM
Sourdough Josh's Avatar
Default Dude, that sucks. You sure you don't have a leak or faulty BPV?
I hold all through 2nd, 3rd, 4th, and 5th gears at 1.3 bar from 2200RPM to 4800RPM, dropping to 1.0bar at 5000RPM.
Old Oct 2, 2002 | 09:45 PM
Audi2ptzero's Avatar
Elder Member
Default Where are you located at and what is your elevation
and are you running logs in hot or cold weather?
Old Oct 3, 2002 | 11:13 AM
kk_1.8t's Avatar
New Member
Albany, NY - Temperature was about 70 degrees F last night when I logged the chart
Old Oct 3, 2002 | 11:15 AM
kk_1.8t's Avatar
New Member
If I had a leak wouldn't I produce about 8 psi or less?! My BPV seems to work fine as well.
Old Oct 3, 2002 | 11:20 AM
Elder Member
Default No, you would just produce the same amount of boost but it would not get to the intake manifold.
But even your requested boost level is lower then it should be. So you might want to call up the dealer you got the chip from and see if they can replace it and see if the problem goes away.
Old Oct 3, 2002 | 12:08 PM
kk_1.8t's Avatar
New Member
Default Anyway I can tell if the BPV has failed? Its sounds normal to me.
I heard if it was failing the BPV would make a hissing sound like that of a BOV. True or no?!?
So far I think it is working.
Old Oct 3, 2002 | 02:46 PM
Well, he had a good point. Your ECU isn't requesting nearly enough boost.
 Michael S. Palmer
Old Oct 3, 2002 | 06:47 PM
kk_1.8t's Avatar
New Member
yes, definitely a good point. I'll have the chip sent back to the tuner. Didn't expect the ECU.
Old Oct 3, 2002 | 10:29 PM
That curve looks very much like the original GIAC software curve, FWIW.
