going engine temp sensor?
Ive noticed that my temp gauge isnt reading 1/2 like it always used to for the last 2 months or so. It seems to fluctuate from normal to just a knotch under normal.
It's never gone above normal which I guess its good, but its not registering normal temp.
Heat is hot, coolant level is good, no codes.
Engine Temp Sensor? I even got a recall notice on it a few months ago covering to 100k, should I even bother taking it to the stealership for that or will they tell me to go pound sand since its modified.
Or, could the thermostat be going with less than 25k on it...?
the back sensor is a bitch behind the head.. buy a new plastic u clip.
the one on the lower rad hose = not a big deal
just both of them are going to cause coolant to pour out
Oh .. if you're changing the one on the back of your head... change out the whole flange. It's worthwhile
but
then again... parts sometimes fail early
oh well sensors are cheap and easier. If they don't fix it. Then it's temp stat.
there has to be a smarter way to attack this though, less trial and error
I always thought the 'real' ECT sensor failures had very erratic temp readings (too hot, down to immediately stone cold, back up, etc) as symptoms.
