Having an shifter issue.
Old Aug 29, 2004 | 11:48 AM
Nojoi|Antisaint's Avatar
Elder Member
Default Having an shifter issue.
When I inspected my Strat SS recently, I found that the plastic assembly that holds the shifter to the linkage, was broken off of the rails that it slides back and forth on. What I think has happened over time, is that the linkage was rubbing against the insulation in the tunnel directly in front of the shifter, making it difficult to operate. Because of this, excessive force was needed to find a gear, as the rubber was fighting the shifter's movement. When I realized this, I sprayed the assembly with white lithium grease, which seemed to solve the issue, until it came back. So, what I'm thinking is that the force needed to get in gear broke the connection to that rail. Now I have way too much play in 1st, 3rd and 5th, while in gear. 2nd, 4th, and reverse are acceptable. Now, the question is, do I replace the cradle that the shifter sits in, or might the problem exist due to some other cause?
repeater
Audi Original "S" Cars
Jun 29, 2017 06:23 PM
NoahWeb
A6 (C7 Platform) Discussion
Sep 28, 2014 11:11 AM
bcr84urq
Nov 9, 2006 12:40 PM
slowEURO
New England Discussion
Oct 26, 2006 08:25 AM
