Head unit problem,
Old May 13, 2007 | 06:26 PM
webfur's Avatar
New Member
Default Head unit problem,
Ok guys, I am taking out my sub and amp, in my 99 a4 2.8q. I got everything removed except I can't get my head unit out, I took out all the screws below the a/c unit, the screws between the a/c unit and head, unit, and the one above the head unit, The darn thing still doesn't come out, I looked in FAQ, couldn't find where the log on it. Its prolly there and I'm an idiot. ack, any help would be appreciated.
Old May 13, 2007 | 06:39 PM
4Rings::G2 boosted::'s Avatar
Banned
Default You need special tools to unlock the headunit
or a nail file might do in a pinch.
Old May 13, 2007 | 06:41 PM
webfur's Avatar
New Member
Default Re: You need special tools to unlock the headunit
I have an aftermarket, head unit, so I got that figured out, I assume that the head unit, the a/c unit all comes out in one piece, or do we need the special tool when I have aftermarket one also?
Old May 13, 2007 | 06:46 PM
Banned
Default if you have aftermarket, you probably have an adapter plate
you've got to figure out how to remove the adapter plate, there are two screws under it that hold the rest of the assembly in place.
Old May 13, 2007 | 06:51 PM
webfur's Avatar
New Member
Default Re: if you have aftermarket, you probably have an adapter plate
ok, wouldn't that mean removing the a/c unit also, honestly I am only looking into disconnection the wires from the amp, and keeping the unit in the car
Old May 13, 2007 | 06:57 PM
Banned
Default without knowing how your aftermarket unit was installed I'm drawing a blank
post some pics maybe that'll clarify where you're at
Old May 13, 2007 | 07:19 PM
webfur's Avatar
New Member
Default Re: without knowing how your aftermarket unit was installed I'm drawing a blank
<center><img src="http://pictureposter.audiworld.com/79873/0513072000a.jpg"></center><p>I want to get to the back of the headunit, so I can take out the wires from the amp. Can't figure it outl
Old May 13, 2007 | 08:50 PM
Abboro00's Avatar
New Member
Default Re: Head unit problem,
Hi, I got mine out in about 15 seconds. What you neeed to do it make yourself two flat pieces of metal. about 5mm wide and about 1mm thick, and about 40mm long, I flattened two nails and then slid them in on each side and the head unit pops out. Good luck!
Old May 14, 2007 | 04:41 AM
Banned
yup, this particular style radio has it's own keys for removal that slide in both sides and unlock
Pointman911
Mar 31, 2018 12:54 PM
Sloooo4esT
Audi Original "S" Cars
Sep 28, 2005 11:02 PM
Solarant
Jan 11, 2003 02:23 PM
shrtbus(w/ cq)
Mar 31, 2002 07:03 PM
GTEJR
May 3, 2000 07:10 AM
