Headlight Connections
I bought some HID headlights cheerfully hoping for a plug and play. After plugging in my year, model and make of my vehicle on ebay and specifically with a seller, the headlights that I now have popped up. Unfortunately for me, the seller sent me lights that do not correspond with my vehicle at all. The headlights neither fit into the headlight cavity on the vehicle nor have the same plugs as the 1999.5 B5 A4 I am working with. I tried to return but, time passed and thisngs didn't happen. Frustrating but I need to make the best of this.
As my vehicle is worth the same modified (cutting the headlight cavities wider) as it is stock, I need to use this investment I have made.
The problem,
Not a single connector corresponds with the headlight connectors my vehicle comes with. Modifying the vehicle doesn't bother me too much but work can't begin until I can find the connections. The original connectors will be cut from the vehicle and the replacements can be spliced into the car.
I apologize if the relevance of this post isn't so specific to the B5 A4. There is not an obvious way to finding these connections, I have tried a couple of websites and they have told me that these connections are more specialized and don't carry them.
Any help regarding will be greatly appreciated
Ballast connection to connect to the vehicle for power
External signal light connector from the new headlight housing
The two cables in the right are internal housing connections, the black piece is the external connection.
internal connector from the new main headlight housing
external headlight housing connector of the new headlights
OEM headlight connection from the vehicle
The OEM signal light nonnection from the vehicle
side view of the OEM signal light connector
http://festyy.com/wNJovj
Visually the connectors seem to match
i know its expensive, but the alternative is retro fitting the corresponding wires to the connector, so unless you know much about car electrics, a simple adapter should be the best way.
How hard would it be to make my own connections? The product looks like it will easily work, but just to make an informed decision.
Any suggestions for electrical schematics of the headlights of the 1999 and 1999.5? I trust my ability to make the splice.
There is a wreckers that buys alot of audi vehicles from my year, the 1999 and 1999.5. The wreckers said that they had the 'pigtails' of the 1999.5 connections which I could splice into the system. Would it be frowned upon to modify the original wiring harness from the vechicle?
