Hella Micro De's Halogen
Old Jun 15, 2007 | 12:36 PM
duke1.8TQ's Avatar
New Member
Default Hella Micro De's Halogen
I installed these fogs on my car the other day, and everything went according to the directions. I mounted them in the same location where OEM fogs are located on 2000+ B5's. They are facing straight, but when i turn them on, they light up the trees like my highbeams. I even adjusted them downwards a bit, but still. Is this how these fogs are suppose to be?
I have HID lowbeams, and when i turn the fogs on, they light up the area above my lowbeam cutoff. The fogs have the HELLA logo imprinted on them, and the directions say to mount them right side up, as i currently do. But i'm thinking, maybe i should turn them upside down instead??
I wrote an email to a HELLA support rep and heres all he had to say:
Casey.Callaway@hinc.hella.com
"Remember that the micro de is a small lamp with big light. Keep the hella logo in the correct position and enjoy the increased vision at night.
Thanks, Casey"
Old Jun 15, 2007 | 12:50 PM
quattro nole (Jeff)'s Avatar
Sounds like you installed them upside down.
Old Jun 15, 2007 | 12:57 PM
duke1.8TQ's Avatar
New Member
No, I said they are currently right side up. I'm considering turning them upside down.
Old Jun 15, 2007 | 01:18 PM
Default Let me re-word.
Regardless of how they're labelled, it still sounds like they're upside down. The beam pattern on fog (or even driving) lights should never shine higher than your low beams.
Old Jun 15, 2007 | 09:54 PM
CTA4AVANT's Avatar
Banned
TJ: Did they fit easily or was it a bit crowded to get them in? They are kind o long.
Old Jun 17, 2007 | 07:23 PM
duke1.8TQ's Avatar
New Member
Default Here they are installed.
<center><img src="http://home.comcast.net/~dukez/Image002.jpg"></center><p>
The driver side is no problem, but the passenger side hits against the 2nd lower air horn. Easily fixed, by removing the lower air horn. Horn sounds funnier, but i can live without it. The one left is enough tooting to tell the driver in front that the light is green, or scare off pedestrians and cats
Actually, you can save the lower horn, but it requires more work than i wanted to do. Just bend the lower horn bracket down and out of way, and extend the connector plug.
Years a 1999 BTW
fe342185
Jul 12, 2010 12:54 PM
krayziekujo
32
Mar 6, 2008 06:53 AM
AlexA4
Apr 3, 2005 12:40 PM
4Rings::G2 boosted::
Mar 6, 2002 04:36 AM
Thomas M.
Mar 25, 2001 06:43 AM
