Help!
Old May 30, 2003 | 02:02 PM
Grn96A4's Avatar
New Member
Default Help!
Can anyone tell me how to get the black plastic out of the handbrake on my car? I got the explanation on the Tech page, but I couldn't get it out by all means. Thanx guys!
Old May 30, 2003 | 02:07 PM
ArandA4's Avatar
Default You mean the black pin thing holding the upper sleeve in place?
Mine's been missing for about a year. I just pulled on it or pried it out and I lost it when it came out. The upper sleeve stays in place just fine when I put everything together.
Old May 30, 2003 | 02:08 PM
Grn96A4's Avatar
New Member
Default Re: You mean the black pin thing holding the upper sleeve in place?
Yep. That's the one. I'm trying to remove my center console and that is one of the things you have to remove besides the 700 other bolts and screws. Do you know how to get it out?
Old May 30, 2003 | 02:14 PM
ArandA4's Avatar
Default All bentley says is: Remove locking pin -3- downward
Not much help. sorry
Old May 30, 2003 | 02:23 PM
Grn96A4's Avatar
New Member
Default Re: All bentley says is: Remove locking pin -3- downward
No kidding! Anybody else?
Old May 30, 2003 | 02:51 PM
Audi2ptzero's Avatar
Elder Member
Default Pull the e-brake up all the way
and look just under the handle where it ends at the very bottom. You will see a square peg, you need to remove that with a flat head screw driver. Start from the top part of the ped which is the side closest to the release button. As you pull it outward it will swing downward.
Old May 30, 2003 | 02:58 PM
Grn96A4's Avatar
New Member
Default Re: Pull the e-brake up all the way
So, I'm going to pull it down and it comes right off, right?
Old May 30, 2003 | 03:06 PM
Grn96A4's Avatar
New Member
I got it out!!!!!
thanks a lot pt <:-p
 Michael S. Palmer
MuHyC
21
Mar 31, 2021 11:30 PM
broncoupe
Q7 MK 1 Discussion
Mar 26, 2013 05:43 PM
SoSolidTT
Jul 18, 2002 03:53 PM
Andy_FL
May 1, 2001 01:44 PM
kyan
Apr 12, 2001 04:30 PM
