Help
Old Apr 11, 2011 | 03:26 PM
Lumpyd's Avatar
Default Help
OK, I have a 1998 A4 Quattro 2.8 stick. I replaced my pads all around and now the peddle is spongy. Didn't think I would have to bleed them, but I guess I do... correct?
And, now, my brake lights won't work. The third light works fine, as do the tail lights when I put the lights on. But, when I step on the brake, it's just the third light that goes on. Any suggestions?
Old Apr 11, 2011 | 04:04 PM
Reggie's Avatar
Club AutoUnion
25 Year Member
Yes - sometimes air gets into the system and you need to bleed. My suggestion is to to a complete fluid change on the brakes. I have found that doing one side at a time and pumping the brakes reduces the chances of air in the system
Not sure what the issue is on the lights. - could be a ground issue or perhaps your bulbs are wrong or burnt.
Old Apr 11, 2011 | 04:30 PM
Lumpyd's Avatar
Well, it's just weird that the bulbs, which have been fine since I bought the car a year ago, would be wrong, or both burnt out at the exact same time.
And, I broke off one of the bleeder screws trying to bleed the system yesterday. It broke off in the caliper. Not leaking, but I cant get it out. Any way around it?
Old Apr 11, 2011 | 05:03 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Didn't change the rotors, huh? Probably should have.
You can probably make it work by bedding in the new pads.
noupy
Dec 12, 2002 05:23 PM
Evanem82
Jul 18, 2002 03:05 PM
Colorado A4
Dec 24, 2000 05:57 AM
Jason Chen
11
Dec 21, 2000 08:26 PM
