HELP!
Old Jan 2, 2005 | 09:34 PM
SDS's Avatar
SDS
Default HELP!
Ok, so I'm driving home today and then the car acts up. It sounded like a clunking noise you get when you get snow built up in the wheel-well. So I pull over, look, no snow. Look around to make sure things are good underneath, can't see anything wrong. Proceed to drive and it starts making the noises again. I have no clue what it is. Pull over again, look, air up the tires a little more, still nothing. Noise is still going on here and there. Well by the time I was almost home, the ABS and BRAKE lights light up. I have no clue what the hell is going on. I called my buddy who's a mechanice and he said could be one of many things. Bad CB joints (or whatever), bad CB boot, something caught between the brake dust shield and rotor, possibly the wheel rotation sensor broke off (I think that's what it's called) or yeah. So I'm wondering if anyone on here has ANY idea what the hell this could be. Like I said, best way to describe the noises made where what it sounds like when you get snow build-up around your tires.
Old Jan 2, 2005 | 10:01 PM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Default ABS sensor is either unplugged, or faulty. BTW, its CV joint, not CB.
CV Joint = Constant <i>Velocity</i> Joint, not CB Joint or whatever.
Old Jan 2, 2005 | 10:15 PM
SDS's Avatar
SDS
Default Re: ABS sensor is either unplugged, or faulty. BTW, its CV joint, not CB.
CV. got it. how much do those damn things cost for these cars?
Old Jan 2, 2005 | 10:27 PM
Keeper of the Cash
Tech Guru
Default ABS sensors? Found some at ECS. Checkout the link inside:
All types and front/rears are $145 each.<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?searchstring=abs+sensor&amp;searc hqt=byvehicle&amp;make=Audi&amp;model=B5+A4&amp;su bmodel=Quattro&amp;engine=1.8T">Clicky</a></li></ul>
Old Jan 2, 2005 | 11:52 PM
SDS's Avatar
SDS
But what is with the noise? Where did that come from? That's my biggest concern.
Novick
Audi allroad
Feb 2, 2007 08:42 AM
fro1156
Audi allroad
24
Dec 5, 2005 03:56 PM
SDS
Jan 3, 2005 11:16 AM
Skibum the Original
10
Jan 6, 2003 10:03 AM
SilverCQ
Dec 17, 2002 10:49 AM
