Help!!!
Old Mar 11, 2005 | 11:37 PM
Psychosel238's Avatar
New Member
Default Help!!!
(long story)
I got my car back yesterday after getting my timing belt replace, So i was pretty excited to take it down to the freeway for a test drive, as soon as I step down to the pedal, i've noticed that there is absolutely no power or boost at all.(by the way i had an 98 A4 1.8TQMS) So I came back to the shop and told them that, my car is acting wierd, so they test the car for codes and then they found out that my throttle body is malfunctioning. Then the check engine light came on, they said that I have to replace my throttle body, so there is another $500 on top of my $1000, timing belt replacement. Today i was driving down the street, everytime that i floored the pedal, the car will shutter really bad, it feels like the car is in hydraulics. Any suggestion that might cost the problem???, I need your help??> Thanks
Old Mar 12, 2005 | 01:02 AM
Im@wesome~ out!'s Avatar
Default Not sure how much it will help... but throttle body adaptation...
From reading the forum there is a mixed bag on how to do this correctly. I'll just tell you three i've heard and you can decide if you'd like to try it. First was put your key in iginition and turn to accesory (sp?). Let it sit for 2 mins you will here clicking during this time... after 2 mins turn ignition to off position. Then wait a couple seconds, then turn on. Second.. just disconnect battery.. let it sit for about a min, then reconnect. Third, Use A Vag tool. Hope some of this helped. I'm not saying i'm right about any of these.. just they are what i've read. I may be wrong
Old Mar 12, 2005 | 05:49 AM
Gottgeschwindigkeit's Avatar
New Member
Default Re: Help!!!
are you sure it is not your MAFS? I recently went through the same ordeal
Old Mar 19, 2005 | 01:36 PM
New Member
Default Update!!
Found out that my spark plugs are loose so i end up replacing just the spark plugs.. Thanks for help.
Daltron
Jun 15, 2009 07:22 PM
Mr. RighTT
14
Jan 18, 2007 07:04 AM
myfootsmells
11
Oct 8, 2005 07:43 PM
STAudiTT
Mar 30, 2004 12:06 PM
IowAudi
Dec 27, 2002 09:02 AM
