HELP!!! Brake issues...
the first thing you need is the right tools for the job. once the calaper starts sticking it can be very hard to get the piston to retract. the link below is show a tool that will make brake jobs a piece of cake. I dont think you need a new caliper but its possible. you can try using a "cube" tool which is much cheaper but not much better then using pliers.
another option is to use the pepboys or auto zone style front calaper tool and use that to put pressure on "the cube" then use channel locks to turn the cube and retract the piston. I've done this many times and it works great.
if you plan on doing this type of work in the future get one of these tools. sears and napa should have them. pepboys auto zone may only have the cube as seen above.<ul><li><a href="http://www.etoolcart.com/browseproducts/Rear-Brake-Caliper-Tool-Kit---NM5311.HTML">http://www.etoolcart.com/browseproducts/Rear-Brake-Caliper-Tool-Kit---NM5311.HTML</a</li></ul>
Works like a charm.<ul><li><a href="http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40732">Harbor Freight tool</a></li></ul>
