Help!!! Cant shift
Old Sep 8, 2006 | 07:00 AM
newports4's Avatar
New Member
Default Help!!! Cant shift
Yesterday while driving my S4, I couldnt shift.
I could not dissengage the gear. When I put the clutch down, the RPMs go down as normal, but can not move the gear shift. After checking the fluids, the fluid resevoir that has the green cap is near empty. Could this be part of the issue. If so, what type of fluid is required to fill this?
TIA,
Bryan
Old Sep 8, 2006 | 07:04 AM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Green cap = power steering. Better hope your PS pump isn't shot.
Old Sep 8, 2006 | 07:07 AM
nunya's Avatar
Try the S4 forums, but it sounds like the slave cylinder.
RallyVermont's Avatar
Mr Mc Feely
busted shift forks... a bit pricy to fix
Old Sep 8, 2006 | 07:14 AM
xdriver's Avatar
Default Do you have a short shifter that you installed? It could be as simple as one of the allens came
loose, and the low fluid is something else.
Old Sep 8, 2006 | 07:15 AM
xdriver's Avatar
nevermind, didnt see that you coulnt move the shifter
Old Sep 8, 2006 | 07:16 AM
Mr Mc Feely
Sounds like the clutch is working just fine.. just can't get out of gear
newports4
Sep 8, 2006 12:22 PM
Lobster
Aug 3, 2006 12:54 PM
RonVon
Aug 15, 2005 12:01 PM
magister militum
Jul 15, 2005 05:03 PM
EGainer
Jun 2, 2004 12:11 PM
