Help: Dim Xenons
I thought the Xenon's were plug compatible (at the harness) w/ the H7's, is that true? If so, what is the likely cause of the lights being so dim? I should mention that one Xenon is slightly brighter than the other -- but neither is as bright as the H7. I used to have a b5 S4 and the color seems about right from what I remember (slight blue white, not yellowish), its just that the output is really low/dim.
What are good sources for replacement bulbs (at low prices)?
Or for the 55 watt upgrade like I'm going to do click <a href="http://www.retro-solutions.com/audiworldGB.html">Here</a>.
One of my bulbs is much dimmer than the other, so I was thinking about replacing the pair, but not for $170!!
i would only run philips or osram xenarc (with a personal preference for the osram bulbs due to their firing sequence).
IIRC I got a used set shipped for around $50. YMMV.
And after getting the new kit I plan on putting my 35 watt HIDs in my fog lights : )
in any case, i'd rather use my good judgment in selecting a nice, used set of OEM bulbs than pay high prices for some no-name "iso9002" bulbs that i have no confidence in...all while supporting a healthy consumer-to-consumer flow of commerce.
bottom line: not all used bulbs are dim, so i don't think it "defeats the whole purpose" to purchase a used set on ebay for the less than the cost of a single no-name capsule.
as always, <b>YMMV</b>
