Help with DTC
Old Dec 9, 2003 | 04:03 PM
homeslice's Avatar
Default Help with DTC
I got a cel the other day Dtc 16795 Secondary Air Injection low flow detected. I'm still under warranty so I'm trying to take it to the dealer
but I can't get the code/cel to come up on the stock ECU. I know they won't fix anything if they don't see the code. I can clear it and It comes up minutes later on the chipped ecu wtf??
TIA
Old Dec 9, 2003 | 04:22 PM
PlainRuss's Avatar
Member
Default Re: Help with DTC
Make sure the engine is cold. Secondary air will run then. If you want to save some time check the vacuumn line right at the changeover valve. They tend to break there.
Old Dec 9, 2003 | 06:18 PM
homeslice's Avatar
Default Yea I did a bunch of runs
Its about 35 degrees here. Still no CEL
Wich one is the changeover valve?
Old Dec 10, 2003 | 03:41 AM
PlainRuss's Avatar
Member
Default Re: Yea I did a bunch of runs
Look on the back side of the head. You'll see a metal valve twords the top and it will have a vacuumn line coming off it. It will also have a plastic tube coming off it as well. Check the vacuumn line right at the valve. You may have to physically feel it it will be brittle.
Noman Mirza
3.0TFSI Engine Discussion
Sep 21, 2016 03:56 AM
Skyrex
Nov 14, 2014 01:38 PM
Mrkrad
12
Sep 14, 2007 03:20 PM
JBSMOOTH
VAG-COM Discussion
Oct 4, 2006 02:04 PM
mobaar
Jul 3, 2005 08:22 AM
