HELP Electric Problems
Old Aug 5, 2005 | 01:50 PM
pnkrckrts's Avatar
New Member
Default HELP Electric Problems
I have 01 2.8. Recently my external temperature gauge has been going from 90 down to like negative 50 and then fluctuating also at the same time my a/c goes out. Also on my radio whe i twist the ***** to change bass mid treb bal fade, the bars dont come up, it alters the sound but i cant see where it is set. Any ideas, i talked to dealership about teh ac temp gauge prob and they wanted 1200 to fix it, ne help would be appreciated.
Old Aug 5, 2005 | 02:04 PM
Yippers®'s Avatar
Member
Default When the outside temp drops below a set temperature the AC shuts down to avoid freezing. The bad
outside temp sensor is likely shutting off the AC as intended. Fix the outside sensor .. not too expensive a part and plug and play . .and the AC should work fine.
The radio .... you're on yer own
89AUDI200
Nov 1, 2011 09:45 AM
kuntaA4
9
Apr 18, 2006 02:46 PM
pnkrckrts
Jul 29, 2005 09:58 PM
Amadeus
Audi 100 / A6 (C4 Platform)
Aug 24, 2004 04:14 AM
sharkTT
Dec 2, 2003 11:38 AM
