HELP...just installed e-codes...
Old Apr 24, 2003 | 05:18 PM
Gulfstar44's Avatar
New Member
Default HELP...just installed e-codes...
can't align the passenger side properly. Just when I think that I've got it right, the brights are screwed up...any suggestions? Pictures of the cutoff pattern on a wall or garage door would be helpful. Thanks
Old Apr 24, 2003 | 05:20 PM
Gulfstar44's Avatar
New Member
PS...if I lose my mind doing this, will the dealer be able to?
Old Apr 24, 2003 | 05:27 PM
maggio's Avatar
Default this isn't my pic, but maybe it'll help you...
<center><img src="http://pictureposter.audiworld.com/38996/ecode_beam_pattern_-not_mine.jpg"></center><p>
Old Apr 24, 2003 | 05:37 PM
Gulfstar44's Avatar
New Member
thanks...I'm way off
Old Apr 24, 2003 | 05:39 PM
maggio's Avatar
lol. the first step to recovery is to admit you have a problem
Old Apr 24, 2003 | 05:44 PM
Gulfstar44's Avatar
New Member
oh yeah...i DEFINITELY have a problem -- and I think I broke one of those POS adjusting screws......
Old Apr 24, 2003 | 05:48 PM
maggio's Avatar
ook! &gt;_&lt;
Old Apr 24, 2003 | 07:18 PM
VicG's Avatar
Default If the brights dont end up being 2 large "dots" the bulb might not be seated correctly.
Heres the quick way to set the low beams.
have a flat area, and a cement wall (like wall of building of shopping plaza. Mark back 25 feet from the wall.
Pull car up to wall so bumper touches wall. Take the spot where your headlights "eye" is and make a spot on the wall at where it would be if you drove car into the wall.
Back up to the 25 foot spot.
Now, adjust so that upsweep spot is on that dot for both lights. Then turn DOWN the DOWN adjuster so that the flat area before the upsweep is about 1.5" below the dot on the wall.
Done.
Now, it is possible to work the worm gear off of the adjuster. You might have to take the lights back out to pull the unit back while you turn the adjuster to re-engage the light housing.
Good luck,
Vic
 Michael S. Palmer
GeZ A4
Apr 29, 2005 12:04 PM
duplicate147489
Apr 12, 2004 05:44 PM
T-Moops
Aug 31, 2003 01:50 PM
MongNan
May 12, 2003 06:23 AM
Wanderer_AG
Apr 29, 2002 12:12 PM
