HELP ME!
Old Jan 24, 2005 | 02:55 PM
twopointeight's Avatar
New Member
Default HELP ME!
Ah! Its like 10 below out and today when I shut my car off (1997 2.8L A4), the sunroof opened (?!). It openened without me touching anything. Now it wont close, is there any easy way to fix this or am I off to the dealer? thanks.
Old Jan 24, 2005 | 03:05 PM
SAC quattro's Avatar
Default This should help
that is- if your car has this sort of set up for controlling the sunroof. I've never been in a 97. goodluck<ul><li><a href="http://www.kris-hansen.com/Audi/srswitch.htm">Click here</a></li></ul>
Old Jan 24, 2005 | 06:12 PM
David.Norton's Avatar
Default For today...
pull the fuse for the sunroof, the number is in the owner's manual, then in the fuse box cover there is a wrench clipped (at least for the 98s if not check your manual, I'm not certain about 97s), open the little door on the bottom of the sunroof motor, insert the wrench into the allen, and crank it closed. That will at least keep you dry until the weather is nicer and you feel like doing something (the URL is good) about it. Good luck with it.
mtnxtreme
Q7 MK 1 Discussion
Jan 5, 2015 04:56 AM
m4ttflynn
Apr 19, 2010 02:30 PM
Simon of Hofstra
Jun 15, 2003 08:58 AM
sebastian018
May 11, 2003 07:38 AM
Audicted
Jun 8, 2001 09:08 AM
