HELP NEED!! 2001 a4 KO4 T w/GIAC limp mode
Old Aug 6, 2008 | 08:33 PM
ogre22's Avatar
New Member
Default HELP NEED!! 2001 a4 KO4 T w/GIAC limp mode
i have 2001 a4 1.8T with KO4 GIAC
as soon as i installed turbo and ECU, took it for test drive.
it doent seem right
boost spike only at 10psi and holding 10 spi
(WTF) and didnt gain any horsepwer or torque.
i know 2001 has some issue when WOT ,throttle cuts it down what should i do to fix that.
i dont know what to do right now
please help
do i have to reconnect ECU and do the TBA?
if i do then can anyone help me how to do TBA please?
Old Aug 6, 2008 | 08:42 PM
DWP's Avatar
DWP
Default TBA? Good idea. I wonder if the post 3 below this one would help.
The one that states "TBA" in the heading
Old Aug 7, 2008 | 08:42 AM
Silver Streakin''s Avatar
Member
Default that's probably not limp mode, but stock file. Are you flashed with your software?
It sounds as if you need to switch to the K04 file.
(soft) limp mode is usually around 5 psi or none at all; 10 is stock for the '01.
Old Aug 7, 2008 | 12:33 PM
DVS27t's Avatar
do you have a vagcom that you can log with?
Old Aug 7, 2008 | 12:40 PM
ogre22's Avatar
New Member
no i dont have
Old Aug 7, 2008 | 12:41 PM
ogre22's Avatar
New Member
they gave me ko4 turbo , all hardware and ecu hammer file for 01
Old Aug 7, 2008 | 01:09 PM
a4_1.8t_01's Avatar
Default Go tothe GIAC site and download the flash loader. Then get a usb vag cable
from ebay and you can switch the files using a laptop. I have the same setup.
alternate_5
Apr 25, 2011 07:06 PM
HunTastic
Jul 1, 2006 11:59 PM
VerrÜckt
Apr 29, 2006 06:17 PM
got_root?
Dec 6, 2001 06:22 PM
BIG NIPPER
Apr 26, 2001 11:23 AM
