Help please !!
Old Feb 3, 2005 | 09:05 PM
Im@wesome~ out!'s Avatar
Default Help please !!
The following leaks are plaguing me.. Oil goes down frequently, power steering leaks too.Could you tell me what these leaks are i'd be so happy. I've put new clamps on the visible leaks but i'm sure there are more. If someone could tell me where common leaks are for the power steering that would be great. 1998 2.8L V6 Quattro Manual
<img src="http://pictureposter.audiworld.com/81277/leak_1.t.jpg">
<img src="http://pictureposter.audiworld.com/81277/leak_2.jpg">
<img src="http://pictureposter.audiworld.com/81277/oil_leak.jpg">
Old Feb 3, 2005 | 09:07 PM
Default That top pic didn't turn out...
<center><img src="http://pictureposter.audiworld.com/81277/leak_1.jpg"></center><p>
Old Feb 4, 2005 | 02:26 AM
Jretal's Avatar
Default if it's dripping off the oil cooler...
and it's actually engine oil, then it's probably from the o-ring between the cooler and the upper oil pan. It's like a $2 at the dealer.
I really can't tell what I"m looking at in the other 2 pix, sorry. Lil more light? I had the lower clamps on the power steering leak before, which was a quick/easy fix. I also had the high pressure lines start leaking at the ps pump, which I had replaced.
hth
Old Feb 4, 2005 | 08:11 AM
RKJ's Avatar
RKJ
Default Traced my power steering slow leak to loose hose at bottom of tank...
Cleaned it up and put a new clamp on the hose and problem has not returned.
syncopated
Q5/SQ5 MKI (8R) Discussion
Aug 14, 2018 07:48 AM
am_ver
Jun 26, 2015 11:52 AM
OMJ
Jul 8, 2010 08:42 PM
Adam T
11
Oct 19, 2000 03:06 AM
