help please i have vagcom codes
VAG-COM Version: Release 409.1-S
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 4B0 906 018 Q
Component: 1.8L R4/5VT G 0006
Coding: 07251
Shop #: WSC 06335
17 Faults Found:
16725 P0341 Camshaft Position Sensor Circuit - Out of Range/Performance
17536 P1128 Long Term Fuel Trim - System too Lean (Bank 1)
17884 P1476 EVAP Emission Control System L.D.P. - Malfunction/Insufficient Vacuum
16826 P0442 Evaporative Emission Control System - Leak Detected (small leak)
16684 P0300 Random Misfire Detected - Any Cylinder
18014 P1606 Rough Road Spec. Engine Torque ABS-SG - Electrical Malfunction
16825 P0441 Evaporative Emission Control System - Incorrect Purge Flow
17833 P1425 Tank Ventilation Valve - Short to Ground
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-10 - - - Intermittent
17829 P1421 Secondary Air Injection System Control Valve Circuit - Short to Ground
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-10 - - - Intermittent
16486 P0102 Mass or Volume Air Flow Circuit - Low input
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-00 - -
17880 EVAP Leak Detection Pump:short circuit to ground P1472 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
Readiness: 0010 1001
any ideas where to start?
but also clear codes and see what come back, many of them could be do to a dead battery at some point.
Wednesday, 11 August 2010, 16:57:16.
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: Redir Fail!
Coding: 07251
Shop #: WSC 06335
4 Faults Found:
18098 - Malfunction Indication Light (K83): Electrical Malfunction
Im thinking it must be the camshaft position sensor, napa told me it takes 2 and they are 130$ a piece, where is the 2nd one located? i know the one on the front by the timing belt. also is there any place online to get this cheaper?
Thanks
Coding: 07251
Shop #: WSC 06335
4 Faults Found:
