Help! It seems my car doesn't have a cooling fan control thermal switch? (EDIT)
Old Sep 10, 2006 | 09:48 AM
Jack in FL's Avatar
AudiWorld Expert
Default Help! It seems my car doesn't have a cooling fan control thermal switch? (EDIT)
V6 30v AHA engine AT
Secondary cooling fan doesn't come on at all (AC/high temp), causing the engine temp to climb up during stop and go traffic.
Figured I'll check the switch first so I look around the lower radiator hose for the switch... and I can't find it. Nothing attached to the hose between the radiator and the engine block. WTF?
EDIT: I also looked around the radiator near the lower coolant hose for the switch to be on the radiator itself to no avail?
Bentley 19-3 item number 8
Any ideas as to the location of the switch?
Old Sep 11, 2006 | 06:38 AM
tobin's Avatar
Default Wrong spot
I have the AHA also. The bentley says it is in the lower radiator hose, but I think that's for the newer V6 engine. The fan switch is actually on the bottom part of the radiator on the driver's side. You will see wires and a connector going into the radiator. Just pull that connector off, replace the sensor, and put the connector back on (coolant is going to pour out when you do this).
Old Sep 11, 2006 | 03:24 PM
Jack in FL's Avatar
AudiWorld Expert
Default D'oh! I saw the plug too, but had no clue WTF it was.
Do you have a part number handy? I figure it shouldn't be too expensive and I'll just replace it instead of testing it, etc.
Thanks a LOT for the heads up, though.
Old Sep 12, 2006 | 04:20 AM
tobin's Avatar
Default Not a part number, but
Go to ECS and get:
Radiator Fan Switch with Gasket (Middle Temperature) ES#1695
Under Engine&gt;Cooling. Get the middele temp one. I have the low temp one and the fan seems like it's almost always on. I'm going to change to the middle temp switch next time the coolant gets drained.<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&amp;engine=V6%2030v&amp ;model=B5%20A4&amp;submodel=Quattro&amp;category=E ngine&amp;subcategory=Cooling">HERE</a></li></ul>
Old Sep 12, 2006 | 04:44 PM
Jack in FL's Avatar
AudiWorld Expert
Default D'oh! Picked one up at the VW dealership today.
A bit more pricy. Oh well.
Do you think it's possible to replace it without draining the coolant?
Pull the old one out, slap the new one in real quick? I figure I will lose some, but not a lot.
Old Sep 12, 2006 | 05:01 PM
JAFO's Avatar
Default i've done it on a golf.....
just be ready and have a pan to catch the coolant.
Old Sep 12, 2006 | 05:29 PM
Jack in FL's Avatar
AudiWorld Expert
Good idea. I have a spare jug of G12, so I should be alright.
spooled_in_saskatchewan
Jun 10, 2013 12:22 PM
MiniSpdRcr
Dec 14, 2007 09:52 AM
mel g
15
Jan 10, 2006 02:43 PM
Avant Sport
Nov 21, 2004 01:20 PM
TEBELLEH
Mar 24, 2004 10:02 AM
