Help with a stereo problem.
thans
-scott
The magic code that is recorded in the trunk is also an "urban legend'. There is a sticker that is supposed to be peeled off when the dealer preps the car. The sticker is put in the car manual. Some dealers forget to do this so the sticker is still there, and a couple of dealers used a sharpie to hand write the code in the trunk because they thought it was a good idea.
The chances of you coming across one of these cars is pretty slim.
When I get my radio code I always write it on the radio frame. Dealer will charge anywhere from $25-125 to get the code for you.
The wiring is all detailed in the manual, if there's an amp it's usually under the rear shelf however it's possible that the symphony setup has the amp inside the unit (there's way more room).
you can use VAG.com to test the speakers I believe. That's where I would start.
http://www.ibiblio.org/tkan/audi/radios/symphony.html
