Hesitation & Power decrease after disconnecting battery?...(30v)
Old Apr 15, 2003 | 12:51 PM
philly.c's Avatar
Default Hesitation & Power decrease after disconnecting battery?...(30v)
I recently installed a sub and after disconnecting the battery, my car seems to have no power at all. Occasionally, it seems to kick in, but it feels as though the engine's not getting enough gas (running 91 oct). In searching, I found that this may be due to the ECU (stock) relearning fuel maps; which leads me to assume that this problem may go away. But, I've experienced this on and off since I bought the car (more since the battery disconnect). I thought this may have been due to a bad O2 sensor, but that's been replaced. Is there anything I can check in the engine bay that I may have not reconnected or something? My car just has no power at all. TIA, phil.
Old Apr 15, 2003 | 01:35 PM
darkman's Avatar
Junior Member
Default you know it could be the battery itself or a poor alternator
if the battery isnt up to standard (which means you prolly need at the least 1000 cranking amps), the alernator might have to work harder or it might take away from the alternator to generate power to run your car.
check that out....find out how many CA/CCA your battery is, and check your meter in your dash..
Old Apr 15, 2003 | 01:56 PM
philly.c's Avatar
I was referring to engine hesitation/power decrease...sorry for the confusion
Old Apr 15, 2003 | 02:06 PM
JAFO's Avatar
did you do a throttle adaption?
Old Apr 15, 2003 | 03:08 PM
philly.c's Avatar
Default will do, just found out about it via good 'ole search
<ul><li><a href="https://forums.audiworld.com/a4/msgs/1319197.phtml">thx, rtb</a></li></ul>
Old Apr 15, 2003 | 03:37 PM
philly.c's Avatar
Default no luck, were these the correct steps?
- disconnect/reconnect battery
- insert &amp; turn key to run
- leave key on run for 2 mins.
- turn key off &amp; remove
- reinsert key and start
do I need to turn it off and back on again before driving...I drove it after the final step
TIA, phil
Old Apr 15, 2003 | 03:44 PM
JAFO's Avatar
i usualy leave it 5 min. but yes that is correct proceedure.
Old Apr 15, 2003 | 04:05 PM
philly.c's Avatar
made sure I heard it whirring, gonna leave 5 mins this time, &lt;crosses fingers&gt;
Old Apr 15, 2003 | 05:20 PM
philly.c's Avatar
Default don't really think that helped, still not at full power
if you have any more suggestions, that'd be great. Thanks!
k2exoman
Feb 15, 2007 01:41 AM
04S4SouthCali
Feb 21, 2006 11:48 PM
cat30
Oct 12, 2004 06:54 AM
Imola Ghost
Feb 24, 2002 03:23 PM
jdulac
Aug 22, 2001 10:52 AM
