Hi, problem with tip mode..
Thanks.
Jack
99.5 1.8QT
Garrett chips
<img src="http://pictureposter.audiworld.com/14332/shifter.jpg">you will need to remove the top handle shifter so you can remove the chrome shifter picture shown below <img src="http://pictureposter.audiworld.com/14332/dscf0024.jpg">
then when you flip it there are couple clips to loose so you can gain access to this little board
<img src="http://pictureposter.audiworld.com/14332/board.jpg">
then use dry cloth to clean the contacts and bent back a bit the metal clips that contact the main board and then put back all the stuff in reverse..
