how to downshift when going fast?
Old May 8, 2000 | 01:08 PM
magiciansampras's Avatar
Default how to downshift when going fast?
I've heard people say that you should downshift on the highway when you want to pass someone. How does one do this without a big jolt? I've I'm cruisin' along at 55 in 4th or whatever and I need to pass someone, should I really throw it in 3rd to get more acceleration??
If so, how do I do this smoothly? I've never been in a situation where I needed more oomph to pass a car, but I thought I would find out just in case I do.
Thanks all,
Marcus
Old May 8, 2000 | 01:14 PM
mark mahadeo's Avatar
New Member
Default You need to match the revs
I think there's a longer discourse on this elsewhere on the forums, and I know there are better drivers on the forum than me, but...
When downshifting you need to hit the throttle just before and during release of the clutch, to bring the revs up to where they should be for the lower gear. A side benefit of this is you can release the clutch much faster if you have the RPMs where the lower gear "expects" them, giving oyu a faster shift.<p>'00 1.8TQS Tip, no chip (yet...)
Old May 8, 2000 | 01:17 PM
Default Re: You need to match the revs
Hrmm.. so if I'm at like 3000 rpm, say, and I want to jump to 3rd to get some more power, I clutch in, physically move stick to 3rd, give it some gas to 3000 rpms and keep the gas at 3000rpm as I lift up clutch?
Old May 8, 2000 | 01:20 PM
CC Rider's Avatar
Default To avoid the jolt, rev the engine while out of gear...
What you want to do is try to match the RPM that you think the engine will be at when you engage the lower gear.
This is a rough example, but if I were cruising along in 5th gear at, say 2500 RPM, then I would do the following:
1) press the clutch pedal in and take the car out of gear (into neutral)
2) press the gas pedal quickly to rev the engine up to where I want it (perhaps 3000+ RPM)
3) put the tranny into the new gear (4th) and let the clutch pedal out
If you are lucky (or skillful) you will have closely matched the engine RPM's for the lower gear and you won't get the big jolt that you are familiar with.
The key is doing this all very quickly, and also knowing relatively what RPM your engine turns for each given speed and gear. Truthfully, I don't watch the RPM's as closely as this sounds. I go to neutral, blip the throttle, and then drop into the lower gear and it tends to work out. The more you do it, the better you will become at it.<p><b>Drew S.</b> <a href="http://members.aol.com/drewinva/audi/" target="drewinva"><img src="http://members.aol.com/drewinva/images/98.5.jpg" border="0" align=center></a> <b>98.5 A4 2.8 qm</b>
Old May 8, 2000 | 01:22 PM
CC Rider's Avatar
Default Oh yeah, once you think you've mastered this, you'll want to try double-clutching!
Old May 8, 2000 | 01:23 PM
can you explain double clutching real quick?
Old May 8, 2000 | 01:40 PM
New Member
If you're at 3000 in 4th, then when you give it gas you probably want to get to about 3800-ish - that's where 3rd will want to be at the same roadspeed.<p>'00 1.8TQS Tip, no chip (yet...)
Old May 8, 2000 | 02:13 PM
FrancisB's Avatar
New Member
Default Re: how to downshift when going fast? - great online resource
Great resource for understanding performance shifting...
answers heel/toe, double clutching, and how to learn,
Highly recommended...
http://home.earthlink.net/~rponiarski/shifting.htm
Regards
FrancisB
 Pouria Savadkouei
 Michael S. Palmer
Old May 8, 2000 | 08:31 PM
jasyn³'s Avatar
Senior Member
Default i keep the gas pedal pressed for a split second as i clutch and down-shift ...
this revs the engine up to the approx revs as i release the clutch in a lower gear. it takes a little practice .. smooth as silk once you get used to it.
.<p>99.5 1.8tqms apr and stuff
-jasyn
Beemer832
Apr 9, 2005 06:59 PM
GDawgA4
Sep 7, 2004 02:36 PM
NH JAY
Sep 7, 2003 10:41 AM
20vTurbo
Jun 25, 2003 01:29 PM
user 46456794
Jul 5, 2001 11:32 AM
