how much of a decrease in performance will 28 pound wheels really make?
Old Jan 22, 2003 | 01:47 PM
  #11
RKA's Avatar
RKA
AudiWorld Uber User
For arguements sake, say 20 lbs (it won't be far from that).
Old Jan 22, 2003 | 01:53 PM
  #12
BoostTed's Avatar
43 LBSish with tires
Old Jan 22, 2003 | 01:58 PM
  #13
silver rain's Avatar
so do you think going from 20-28 pounds a wheel would make a significant difference in performance?
Old Jan 22, 2003 | 02:01 PM
  #14
ex-quattro PETE's Avatar
AudiWorld Expert
Default If you're drag racing (1/4 mile) or tracking - yes, if just casual street-driving...
then I'd say you won't notice much difference.
  #15
plug1's Avatar
Default Not that much, but you will notice it, yeah.
Thats a 2" difference in size and i'm sure the 17's you're looking at will be wider...and the more surface touching the ground, the more friction is created. With 8lbs of unprung weight, you'll be slower...but nothing too significant, i guess...unless you're heavy into tracking your car in one form or another.
Old Jan 22, 2003 | 02:09 PM
  #16
RKA's Avatar
RKA
AudiWorld Uber User
Default Yes!
Especially on a 4 cylinder car, you'll feel it off the line (before the turbo kicks in to help you out). Once you get moving, it won't be such a big deal.
Also, as plug1 and WYSIWYG are pointing out, your stock wheel and tire combo currently are very light, and offer a very small contact patch. Going to a 28 lb rim means you're probably looking at 17's or more likely 18's. An 18" tire will also be heavier than a 15" tire. That weight is likely to be in the neighborhood of 5 lbs by itself...all on the outside of the wheel...the most significant place to add or save weight. The larger contact patch will change the feel of the steering completely, as will the stiffer sidewalls. All that is good, but realize, you'll feel the added unsprung weight, imho.
Initially, you'll say it's not so bad, and the performance increases outweigh the performance decreases. Over time, if you find yourself switching back to a lighter 17" wheel, you'll realize just how different those heavy wheels were! Ask Sameer. He switched from a 25 lb 18" wheel, to a 17 lb 17" wheel.
CRAMAZING
A6 (C7 Platform) Discussion
Oct 21, 2014 03:41 PM
dkash8
Nov 5, 2008 07:30 PM
ESFO
Apr 28, 2004 09:52 AM
[not Steve] Trac
9
May 11, 2001 07:55 AM
FrancisB
Wheels & Tires Discussion
10
Jun 7, 2000 07:54 PM
