how to replace engine mount on 12v?
now a month after engine rebuild, I started to feel cluk from somewhere on front side.
I have all new control arms, and I don't think they are the cause.
When I was assembling engine back to the car, I did not tight the upper engine mounting bolts enough because I forgot to do it when I should have, and tried to tight them later, but no space...
I did as tight as I can, but I think that became a problem.
Is there a way to replace engine mount with out cherry picker?
I'll replace thermostat as well, so opening radiator is fine.
Also, I think my AC compressor is making sound. I just filled AC refrigerant at AC shop, and it is making noise (with bit of vibration) after that. Do I need to visit the shop, or will that go away?
Thank you in advance.
