How serious is this problem?
Old Aug 17, 2003 | 05:45 PM
tobin's Avatar
Default How serious is this problem?
I was checking out this 98 2.8 for sale, the guy said that really the only thing wrong with it is that the upper oil pan gasket leaks. he said its just a silicone seal, not a real gasket, and requires 4-6 hours of labor to fix, so about 350-500 bucks to fix. how serious a problem is it, and how hard is it to do it myself?
Old Aug 17, 2003 | 05:53 PM
paul_858's Avatar
AudiWorld Expert
Default you can do it yourself. :) basically drain oil, remove pan(might require disconnecting one side of
sway bar), clean existing sealant off both sides, add sealant, replace pan, torque to spec, replace oil filter(if it needs to be) fill oil back up done.
Andronikus
Jul 8, 2013 05:41 PM
sbmellen
Nov 10, 2008 11:24 AM
kitter32
Jan 31, 2007 11:53 AM
n2000snake
Jan 29, 2007 08:04 AM
