how to tell if intake temp sensor is faulty?
The temperature outside was about 5 C (40 F), and the car has been parked for 5 or 6 hours.
Took VAG-COM to it, took measurements of intake temperature sensor. The readings I got were about 21 Celsius (70 F ) at idle, dropped a few degrees when I hit the accelerator (I'm guessing it's sucking the air at a faster pace, so it's cooler).
It's odd that the temp reading was so high.
Any insight is appreciated.
The various sensors should be reading close to ambient air. Check your engine coolant temp reading. See if it looks wacky.
however, would coolant temp of 90 F turn on the fan?
Your Audi should run about 91C , make sure you are not mixing up units.
At 90F only the electric fan would be running with the AC on. Below 40F ambient the AC could be blocked by the outside air sensor so the fan won't run. Check for the snowflake in the cluster.
I switched to Econo mode on the HVAC controls, but the fan still spins.
