Hub Shark
My original thought was that I would remove the entire knuckle and bring it to a machine shop to press out the bearings and put the new bearing in and then put it all back. This is a bit of a hassle, because of the work involved removing the knuckle, driving 20 minutes to the shop, waiting, taking it back. Plus, the only real time I have to do this is on a Saturday or maybe at night, and the car is needed during the week. The machine shop is only open until 10 or 12 on Saturday and closes at 5 or 6 during the week...so this is a bit problematic.
Enter Harbor Freight Tools - they have a knock-off of the Hub Shark for sale for $100. This tool, in theory, should allow me to remove the bearings while the knuckle is still attached - which will save me a lot of machine shop hassle in addition to the disassembly hassle.
Some people seem to have great results with this, and other seem to still need a press. I'm a bit nervous that I'll waste time cutting corners. Does anyone have any experience with this tool on an A4?
Thanks!
Two important tips, First, when removing a bearing, whack the end of the removal bolt with a sledge hammer a couple of times when the impact wrench stops turning. You may have to do this 10X or more. Second, make sure that the inner race is supported when installing the hub. If you don't, you the destroy the bearing.
Thanks!
I guess for $80 ($100 with a 20% off coupon) it's worth the risk that it doesn't work. Like I said, if it works 2X for me, it saves me time and probably costs less than the machine shop will charge me each time....if it doesn't work I wasted $80 and I just continue taking it apart so that I can get it to the machine shop.
http://www.harborfreight.com/automot...ers-66829.html
There's no issue with it being described as for FWD front wheel bearings, right? This should work no problem on a B5 Quattro rear bearing, correct?
Thanks!
I will most likely be trying this weekend.
