Huge Auto Transmission leak
Old Aug 23, 2008 | 03:44 PM
mtroxel's Avatar
Default Huge Auto Transmission leak
96 A4 Q with the V6. 5 Speed automatic transmission. Transmission fluid came pouring out last night...no warning. Barely made it home. Get under it. I see no leaking in the cooling lines that run from the radiator. Fluid all over the pan...way up front on the tranny. I might guess front seal, but isn't that differential (gear) oil up front right behind the fly wheel? And a seal would start leaking gradually, not all of the sudden....right?
Any ideas of where fluid would just suddenly drop out of the car?
Old Aug 23, 2008 | 06:47 PM
Audi Junkie's Avatar
Community Builder
Hoes?
Old Aug 23, 2008 | 08:02 PM
Allroady DungBeetle's Avatar
Default Front seal (yes there is fluid up front) diff gear oil is separate - or cracked torque converter.
Could be where the cooling lines connect to the trans or it blew a plug/connector out due to excess pressure from a clogged vent line.
Clean it all off with simple green or something and try and pin-point the leak.
Old Aug 24, 2008 | 06:12 AM
mtroxel's Avatar
Default Re: Front seal (yes there is fluid up front) diff gear oil is separate - or cracked torque converter
I have 236,000 miles and have never changed the filter. Could a clogged filter send the fluid out of the tranny?
Bentley says I need a special tool to fill that tranny. Can I just force a hose up into the little fitting?
Old Aug 24, 2008 | 07:09 AM
myers1.8TQ's Avatar
I was lost, now I'm found
Default How I did it . . .
<img src="http://pictureposter.audiworld.com/147179/tranny_oil1.jpg">
<img src="http://pictureposter.audiworld.com/147179/tranny_oil2.jpg">
<img src="http://pictureposter.audiworld.com/147179/tranny_oil3.jpg">
<img src="http://pictureposter.audiworld.com/147179/tranny_oil4.jpg">
Old Aug 24, 2008 | 07:16 AM
mtroxel's Avatar
Default Re: How I did it . . .
wow nice. You get that hose and the fitting at an auto parts store?
Old Aug 24, 2008 | 07:19 AM
myers1.8TQ's Avatar
Yes, and went to a home improvement store and got i think 6 more feet of the same size tube
Old Aug 24, 2008 | 07:21 AM
myers1.8TQ's Avatar
Oh and lucky you, look 2 threads up.
Old Aug 24, 2008 | 11:48 AM
audinutt's Avatar
Default Sounds like your main seal is gone more than likely a result of pump failure
check out my pics of what happened, several others have experience the same failures, I got lucky and found a ZF trans and converter new from around 2K shipped.<ul><li><a href="http://rich.homeunix.com:8888/Trans/">http://rich.homeunix.com:8888/Trans/</a</li></ul>
mtroxel
Aug 23, 2008 12:03 PM
TOMAS7
Apr 20, 2008 02:58 PM
ck256
Dec 9, 2007 07:03 PM
Sallad
9
Sep 23, 2004 09:37 AM
sk88erguy
Oct 27, 2003 05:00 PM
