I pulled a homer...
Old May 28, 2003 | 09:31 AM
Mica's Avatar
Banned
Default I pulled a homer...
I was returning my car to stock...
i took off my kamei grill, and put on the stock one.
i forgot to pull the hood latch, and now when i do, the lever doesn't pop out... so the hood only goes up arounf 2 inches.
what's the best way to rectify this situation?
Old May 28, 2003 | 09:33 AM
paul_858's Avatar
AudiWorld Expert
Default pull the grill out. Since it just pops into the hood, use some zip ties to go through the slats/
mesh of the grill, pull the grill out gently but firmly, then try to pop the hood again.
Old May 28, 2003 | 09:35 AM
Mica's Avatar
Banned
How can i wrap the zip ties around the latches?
Old May 28, 2003 | 09:38 AM
paul_858's Avatar
AudiWorld Expert
Default ok you put the factory grill in right? get yourself some long zip ties, thread it through the slats
in the grill, use a pair of pliers/tweazers something to get the end you threaded through out the bottom of the slat you went through... tighten the zip slightly so that it forms a loop, do this a few times and slowly pull the grill till it comes free on one corner and continue till the grill off the car.
Mica's Avatar
Banned
oh nvm, i get it, lemme go try
Old May 28, 2003 | 09:51 AM
Mica's Avatar
Banned
Default Didn't work... i put the loop of a schicabob type thing around one
of the vertical plastic... things, tugging... it's not going to happen.
Old May 28, 2003 | 09:53 AM
paul_858's Avatar
AudiWorld Expert
Default take a picture of this if you can. post it up so we can see what/where the latch is and how the
grill is.
you want to pop the entire grill out so that the latch will move freely.
Old May 28, 2003 | 09:55 AM
Mica's Avatar
Banned
k, hold on
Old May 28, 2003 | 10:00 AM
Mica's Avatar
Banned
K, go to www.lostsite.com/paul/
Old May 28, 2003 | 10:05 AM
paul_858's Avatar
AudiWorld Expert
Default ok that last picture was just funny :) ok, you know the long horizontal slats that go from the
rings to the end of the grills? can you put force on them at one of the ends to pop the grill out partially? In the pictures i can't see if the hood latch is through the grill or not, or if it's stuck behind it.
