Identify this rattle...
Old Nov 19, 2002 | 10:22 AM
ex-quattro PETE's Avatar
AudiWorld Expert
Default Identify this rattle...
Only happens on cold start-up, and lasts about a second. Comes from under the hood. Sounds more plasticky rather than metallic.
I've heard some people mention belt tensioner? Is that it? Is it a warning sign that it's going bad and needs immediate attention?
Old Nov 19, 2002 | 10:27 AM
Silver Streakin''s Avatar
Member
cam belt tensioner. I still can't get a tech to actually hear it.
Old Nov 19, 2002 | 10:34 AM
paul_858's Avatar
AudiWorld Expert
Default as stated, cam belt tensioner... leave the car with the dealership overnight so in the AM they can
start it up and hear that noise.
it's going to only get worse and worse.
Old Nov 19, 2002 | 10:49 AM
skabaru's Avatar
Default yup cam belt tensioner...
it will eventually throw a DTC... and then, eventually, your car will stall on startup...
I have had it repalced twice, the current one is holding out much better... 25,000 so far...
Old Nov 19, 2002 | 11:21 AM
AudiWorld Expert
are there any serious risks of damage to the engine when the tensioner fails?
Old Nov 19, 2002 | 11:25 AM
Chard's Avatar
Default does it sound like this?
kinda like a small chainsaw is in your engine bay...makes the noise when you turn your wheel from side to side, but goes away right when the car warms up a little?
My car JUST started this yesterday morning.
If it's the cam belt tensioner, how much is it to get replaced? DIY? I'm JUST out of warranty.
BTW, what does it do, besides create tension on the cam belt =P
Old Nov 19, 2002 | 11:30 AM
AudiWorld Expert
you sound like you have power steering problems - are you low on PSF?
Old Nov 19, 2002 | 11:43 AM
Chard's Avatar
where's the resovoir, so I can check?
 Michael S. Palmer
Old Nov 19, 2002 | 11:47 AM
AudiWorld Expert
on the right, near the windshield washer reservoir, IIRC.
Old Nov 19, 2002 | 11:48 AM
Chard's Avatar
i'll check, brb
