Injector
Old Sep 29, 2005 | 09:41 PM
SlvrK04Audi's Avatar
New Member
Default Injector
hi all,Noob here... with a 2000 1.8T Qms ko4/J31 File. well recently i have had a blinking Cel at idle, when vaged it ended up being cylender #2, so i replaced the coilpack and it didn't make a diffrence...so i took the fuel rail out today, After figuring out how to drain the fuel.... thank to AW, and ended up placing the injectors on top of a pice of cardboard... and crank the motor... all except cylender 2 had wet spot's under the injector.. i guess i need a new injector... or do you think it can be sent out and cleaned up? and where can i get a good pice online for the injector? Should i look into buying a set of four 315 cc made by bosh, on ebay? TIA
Old Sep 30, 2005 | 10:16 AM
j31izzle's Avatar
Default what injectors do you have now?
check FI classifieds on vortex, a good source of such things.
Old Sep 30, 2005 | 11:48 AM
New Member
Default Re: what injectors do you have now?
Thanks, ill try the FI classifieds... the injectors are the stock ATW 06B 133 551 B 0 280 155 825 iam not sure on the cc's but i think i Read 270 somewhere.
Old Sep 30, 2005 | 01:47 PM
j31izzle's Avatar
Default you're running those with the J31?
yeah i think they're either 270 or ~240?
what are you running your afpr at then?
Old Oct 1, 2005 | 01:25 AM
New Member
Default Re: you're running those with the J31?
fpr is a bosch 4 bar... i just ordered one for at http://4usedaudiparts.com , for 80 bucks
MySTG3S4
Jun 6, 2009 04:04 PM
myfootsmells
32
May 16, 2005 11:07 AM
Jason Chen
Aug 3, 2004 12:19 PM
mmart6545
Mar 1, 2004 12:05 PM
BTCC A4
Sep 5, 2002 07:02 AM
