inner tie rod end replacement - happening now - need help with boot removal
Old Jan 3, 2009 | 08:09 AM
egustaps's Avatar
Default inner tie rod end replacement - happening now - need help with boot removal
I have the car jacked up, front driver side wheel off, tie rod unscrewed from the suspension structure, so the tie rod is only connected to the steering rack. I am replacing the entire tie rod (inner and outer) as the two will not separate (I've tried to separate them for 6+ hrs a couple months back).
Question is: How do I remove the boot (bellow) that is attached to the steering rack and covers the inner tie rod end? I was hoping to avoid cutting it up, and be able to reuse it.
Any help appreciated.
617 359 1254
Old Jan 3, 2009 | 08:33 AM
trancesp0t's Avatar
Default The boot is held in place to the rack by a one time use clamp.
You will need to pry it off with a flat head screw driver. Make sure you have a replacement clamp before you do this.
Driver side is easier to work on than the passanger side which seems to be deeper into a wheel well. Passenger side was really a bitch to me when putting a new clamp on the boot.
halik
17
Aug 3, 2014 09:02 AM
JaredKane
Oct 31, 2009 03:24 PM
quattrolife
Audi 100 / A6 (C4 Platform)
9
Jul 22, 2009 04:03 PM
Tthomas
Jan 1, 2006 08:40 AM
Nasti
Dec 14, 2004 02:12 PM
