Installed Forge DV and..
Old Nov 3, 2003 | 01:40 PM
mikeee's Avatar
New Member
Default Installed Forge DV and..
it was a pain in the but. First of all, on my car(97 A4) the dirverter valve is playced up by the turbo. Not down lower which made it harder to get too. Then once it was off, we found a huge hole in the hose running from the air box to the compressor side of the turbo. I couldn't believe how big it was! Anyway, fixed it all. and now the car has much more power lower in the revs and the boost peaks have are for the most part, gone.
Old Nov 3, 2003 | 01:46 PM
Audi2ptzero's Avatar
Elder Member
How do you like your Matrix Engineering exhaust?
Old Nov 3, 2003 | 02:18 PM
mikeee's Avatar
New Member
Default Re: How do you like your Matrix Engineering exhaust?
Great. It is 3 inch pipe from the turbo back with 2 borla mufflers. It gives the car a deep tone and its pretty loud. i havent heard alot of other a4's with exaust so i dont no what to compare the sound to but i like it alot
as far as performance goes, it oppened up the dop end completely. with a ko3 it pulles hard from 3500 to 7000. there is no power drop of any more.
were are you located?
Old Nov 3, 2003 | 07:07 PM
Elder Member
Default I have the proto type on my car now that was built for
Garrett's (GIAC) car. I moved the HFC under the car just after the 3" flex section and mine only uses 1 magnaflow muffler at the rear.
I am located in Socal "Riverside County" area.
Old Nov 3, 2003 | 10:57 PM
mikeee's Avatar
New Member
Default Re: I have the proto type on my car now that was built for
Ive got the cat place in the normal spot but it was a ceramic cat and it is hollow now. They had it set with one borla, but added a second because it was too loud. the only problem i have is that it is very low and i have problems not scraping.
Old Nov 4, 2003 | 05:31 AM
Elder Member
Do you have any pics of it on the car?
naasifsalie
May 6, 2015 11:50 AM
SlutMonkey
Mar 16, 2006 06:25 PM
eUROminded
13
Oct 20, 2005 04:44 PM
eg95og
May 27, 2005 10:07 AM
bjaro5187
May 14, 2005 06:55 AM
