installing cd player
Old Jul 30, 2003 | 09:28 AM
putzman's Avatar
New Member
Default installing cd player
i have installed a Pioneer DEH-P8500MP into my 99 audi A4 and everything works fine but i am getting no sound out of my rear speakers and i checked all the connections to the wiring harness and can't figure it out?
Old Jul 30, 2003 | 09:31 AM
kenny (dremel)'s Avatar
if u test the connections at the rear speakers with a multimeter, are you getting any readings?
Old Jul 30, 2003 | 09:48 AM
nonsito's Avatar
New Member
Default Re: installing cd player
are u using aftermarket amp?
go to tech section and u will see the procedure of wiring the back speakers. there have their own amp and if u use the adapter for the headunit u will find out that the rear does not plug into it.
Old Jul 30, 2003 | 09:53 AM
putzman's Avatar
New Member
Default Re: if u test the connections at the rear speakers with a multimeter, are you getting any readings?
the speakers worked with the factory radio and i don't have or know what a multimeter is
Old Jul 30, 2003 | 10:36 AM
nonsito's Avatar
New Member
put it like this, you're back speakers are connected to nothing (except the old radio).cos u dont have a meter reader, get a speaker and run a wire from the headunit (preferable the back speaker wire)to the speaker, and find out if u will get any sound. all the speakers that came with our cars are wussy so u will need to get all new SPEAKERS and AMP. you will need to run wires (sidewalls) from the headunit to the back speakers. if this cannot help find somebody around u to help.
Old Jul 30, 2003 | 12:51 PM
putzman's Avatar
New Member
Default got it
yeah basically the amp is blown and i prolly need another amp or just by pass it but thanks for all your help, i'll be sure to post again if any problems
Jerseycq
9
May 11, 2007 09:34 AM
txxp4
Jan 24, 2007 07:01 PM
jaybyrd6
Jul 27, 2004 06:20 AM
Afroney
Nov 7, 2002 06:00 AM
Stealth Bombaz
Jul 6, 2002 04:00 AM
