I've lost count...
Old Feb 25, 2007 | 02:31 PM
qfrog Ti20's Avatar
Default I've lost count...
of how many rear wheel bearings I've gone through... my avant now needs it's right rear done, it lasted longer than the left rear by a good measure which I had done at 65k or so now I'm at 100k.
Old Feb 25, 2007 | 02:37 PM
alms_lefko's Avatar
80k and none replaced 'knocks on wood'
Old Feb 25, 2007 | 02:40 PM
AaronBryan's Avatar
I've done 6 at 140,000 miles
Old Feb 25, 2007 | 02:49 PM
Silver Streakin''s Avatar
Member
0 at 91k
Old Feb 25, 2007 | 02:51 PM
Carson (K03x2)'s Avatar
Default The GTI hasn't needed any rear wheel bearings, 106K and counting
The front wheel bearings are another story, I've been through lots of them.
Old Feb 25, 2007 | 02:58 PM
Longwolf (Christian)'s Avatar
My '00 needed front bearings at 60K, and my wife's prior '97 needed the rears at 60K.
Old Feb 25, 2007 | 03:11 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Interesting that this seems to be an A4 thing. A6's of the same vintage never need bearings.
Old Feb 25, 2007 | 03:23 PM
Ertman's Avatar
Default 300K...
kilometers that is and none since I have owned it (last 80K miles). I was beginning to think that one might be going until the wife's Honda needed one at 39K. Now I know exactly what a bad bearing sounds like.
 Michael S. Palmer
Old Feb 25, 2007 | 04:47 PM
TANMAN's Avatar
Member
Default Mine have been good. RR went at 90k, LR is going now at 100k.....
Pretty good I guess. Next week I'll replace the left one.
Old Feb 25, 2007 | 04:53 PM
AMSroadrunner's Avatar
New Member
Default It's the ground!
I had issues until some one said to make sure that the chassis was grounded to the body. I ran a couple pieces of grounding strap from the battery ground on the body to the block (same bolt) then to the subframe and haven't had an issue since.
Don't know if that is just dumb luck or actually solved something!
Good luck!
Andrew
