kill switch questions
I hope these ideas will help....
I like the idea of running 2 wires from the relay box, under the trans tunnel and installing a small toggle switch in the rear ash tray...or even better, my 99.5 has a "blank" spot where the OBDII plug used to be...it can be mounted in their..
stay safe
DG
wire the relay to the shifter colum under the shifter boot, toggle switch (fuel)
cut off the ciggy lighter's power, wire the fuel wire to it, then use an old cell phone adapter, open it, close the circut, plug it in to start and drive (fuel)
note: fuel pump relay takes about 2 hours to compeletly "kill" the car, if you just stop the car and someone start your car, he would still be able to drive about half a block or so. As with the high beam ignition kill, it's a hassle if your car is being valet or back to the dealer for service.
