Koni Coilover question
Old Jul 26, 2004 | 06:36 PM
raugusta's Avatar
New Member
Default Koni Coilover question
I just bought a used set of Koni Coilover. I noticed that the shocks didn't go back to extended position when I pushed it down. I actually had to pull it out to return it to the extended position. Is it normal?
Also, how to adjust the damping on the rear shocks?
Old Jul 26, 2004 | 06:38 PM
starting ...'s Avatar
Default It is normal
I took a small allen key. At the top of the shock you put it in the little holes.
Old Jul 26, 2004 | 06:41 PM
raugusta's Avatar
New Member
Default Are all 4 adjustable?
I only noticed the allen hole on 2 of the shocks...What about the other 2?
Old Jul 26, 2004 | 06:42 PM
for the fronts push them all the way in and twist with an allen key.
Old Jul 26, 2004 | 07:04 PM
raugusta's Avatar
New Member
Default Re: for the fronts push them all the way in and twist with an allen key.
Push them all the way in, and then twist what?
Old Jul 26, 2004 | 07:17 PM
the shock. the part that you just pushed all the way in.
Old Jul 27, 2004 | 08:19 AM
SolidFish's Avatar
Junior Member
Default I thought if the strut dont extend, then its not good?
When you blow a shock, doesnt it fail to errect? (sounds funny)
Does Koni Coilovers come with warrenty?
Casablanca Avant
Mar 13, 2008 03:29 PM
1.8Steve
May 9, 2003 08:57 AM
esfor
Apr 30, 2002 08:19 AM
steveinhisroom
Sep 7, 2001 04:00 PM
pixA4
Jun 25, 2001 10:14 AM
