Leaking steering rack
Old Oct 13, 2005 | 01:54 PM
Hoof Hearted's Avatar
Default Leaking steering rack
My steering rack is leaking more then a frat boy at kegger... ...how much of galactic PITA is it to R&R the rack? Any ideas on where to obtain a replacement? Blau?
TIA.
Old Oct 13, 2005 | 01:58 PM
Carson (K03x2)'s Avatar
Default Its no walk in the park
1.8T is much easier than V6. You start by removing the steering column connection, and following that, you'll need to remove the battery, disconnect the tie rod ends from the steering knuckles, remove the steering rack bolts on the driver's side (12 point 10mm) and loosen the passenger side bolt. Then you remove the banjo bolts from the steering rack, and once its all disconnected, slide it out the driver's side.
Old Oct 13, 2005 | 02:04 PM
Default I didn't suspect it was a cake walk...
do you need to remove the driver's side strut or just the wheel? Good time to upgrade the tie-rod ends...
Old Oct 13, 2005 | 02:08 PM
qfrog Ti20's Avatar
we dont have struts
Old Oct 13, 2005 | 02:09 PM
RKA's Avatar
RKA
AudiWorld Uber User
You actually made that sound pretty easy.
Old Oct 13, 2005 | 02:35 PM
Default I did? Well, I apologize I guess
Its not as hard when you have a lift. I wouldn't do one in the driveway, but thats me.
Old Oct 13, 2005 | 02:45 PM
Ritz's Avatar
on a 1.8T it's actually not that bad.
Old Oct 13, 2005 | 03:21 PM
True, doing V6 racks really sucks.
Old Oct 13, 2005 | 04:54 PM
Ritz's Avatar
I haven't had to do one yet. 8-)
Old Oct 14, 2005 | 03:06 AM
Jretal's Avatar
Default nothing but good times...
<img src="http://pictureposter.audiworld.com/21175/dscf0034.jpg">
I did a half a$$ed <a href="https://forums.audiworld.com/a4/msgs/2341249.phtml">write-up</a> on R&amp;R'ing my p/s rack. Wasn't hard, but took some time. Might have been cuz I was uber hungover, but that's neither here nor there
Lemme know if you have any questions I'll see what I can do to help ya
