leaking trunk
Old Dec 27, 2004 | 07:52 AM
rammer's Avatar
New Member
Default leaking trunk
Help!
I have a '99 A-4 and the trunk is leaking between the lid and the rubber seal. The seal looks clean and has no tears. Is there an adjustment or does the seal have to be replaced.
Thanks
Old Dec 27, 2004 | 08:49 AM
S7's Avatar
S7
Default where is the leak exactly?
If you dunno, pressure wash and trace it through. IMO-if the lid lines up perfectly, get a new seal. Weird though b/c the seal attaches to steel lip that should channel most water away regardless.<ul><li><a href="http://bister.myftp.org/fun/audio/buttplug.mp3">smartass solution for leaky trunk</a></li></ul>
Old Dec 27, 2004 | 09:05 AM
rammer's Avatar
New Member
Default Re: leaking trunk
The leak appears to be all the way along the top of the seal below the rear glass. that's why I was wondering if there is an adjustment to put more pressure across the seal.
Old Dec 27, 2004 | 09:16 AM
ddderekkkkk's Avatar
Default i've had this problem
just get some bicycle patch and patch up the leak. this will do the job.
Old Dec 28, 2004 | 10:30 PM
rammer's Avatar
New Member
Default Re: i've had this problem
Thanks for the info.
I will give it a try.
4000fixes
Nov 9, 2007 02:58 PM
sidespar
Nov 9, 2007 10:57 AM
austinado16
Jan 15, 2006 01:53 PM
lanciat
Oct 29, 2004 11:57 AM
duffWL
Mar 3, 2004 12:20 AM
