Looking to get an 01 A4...
Old Oct 16, 2006 | 11:49 AM
churd27's Avatar
New Member
Default Looking to get an 01 A4...
I am looking at a 2001 A4 1.8T Quattro 5 Speed that is priced really well at $8995 but the mileage is pretty high and scaring me away. It has 99,960 miles. Anyone have any advice or things I should look for on the car?
Old Oct 16, 2006 | 11:58 AM
BRC's Avatar
BRC
Junior Member
Default make sure the timing belt and water pump have been changed, tire rod ends, control arms, brakes and
I would take it to a mechanic that you trust and have them check it out. The car will be fine with that many miles as long as there isnt to much deferred maintenance.
Old Oct 16, 2006 | 12:06 PM
Silver Streakin''s Avatar
Member
Default which means you could offer $7500 and probably get it for $8k out the door. ::sigh::
with 100k, I'd look over every engine oil, trans, and diff seal.
timing belt, water pump, etc. service would need to have been done by 60-75k.
check all control arms, TREs, etc.
exhaust for leaks.
make sure the a/c works.
typical used car buying stuff.
Old Oct 16, 2006 | 12:12 PM
youcantseeme's Avatar
Senior Member
Mine has 92k and runs fine... so far.
Old Oct 16, 2006 | 12:23 PM
jprice@CPS's Avatar
Member
Default all vac lines will need to be replaced if they haven't been yet. Check L hose too.
other things:
suction jet pump
valve cover gaskets
cam adjuster gasket
Old Oct 16, 2006 | 12:25 PM
ImAwesome's Avatar
Senior Member
buy mine... much lower miles.. LMAO
Old Oct 16, 2006 | 12:41 PM
pac1085's Avatar
u can buy a new 911 turbo for what you've spent on your car!
Old Oct 16, 2006 | 12:43 PM
ImAwesome's Avatar
Senior Member
shush you !
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 16, 2006 | 12:52 PM
IBG's Avatar
IBG
Default lol, by the time he's done with the A4 he could have bought an Enzo...
or two. :-)
Old Oct 16, 2006 | 03:03 PM
beejohn's Avatar
dont buy an 01.. go dbc
