maf?
Old Jan 29, 2006 | 09:52 AM
baze's Avatar
New Member
Default maf?
HI readers i have an 01 1.8 with the pes t28 and just tightned all the hoses and all of a sudden the car is pushing like 30 ibls of boost,but breaking up like crazy if i keep it floored,could this be the cause of a bad mass air flow sensor or a bad n75valve? Also i have the stock ngk audi plugs ,could those also be contributed cause? thanks
Old Jan 29, 2006 | 09:57 AM
mAd1(gt3071r)'s Avatar
Member
Default check the line which goes from the wastegate up
but yes, even a bad N75 could do it. Do you have a VAG handy? The reason it's breaking up is due to the excess boost. Your ECU is picking up the boost and closing the throtle so you don't blow up your engine. You can actually observe this with a vag and watch the block for the throtle plate angle. When it breaks up, it should return to 0 degrees.
Old Jan 29, 2006 | 12:51 PM
beejohn's Avatar
Default try and get that problem fixed before flooring it everywhere
30lbs of boost is a bit much, probably running lean = engine blow up.
ziggycbr07
1.8T Discussion
Oct 3, 2011 10:37 AM
graviTT
Jan 20, 2007 10:30 PM
leosphere
Aug 18, 2005 01:48 PM
ArandA4
VAG-COM Discussion
Jul 20, 2004 02:02 PM
sales@avalonmotorsports
9
Dec 11, 2001 08:48 AM
