malfunctioning engine light
Old Apr 8, 2003 | 07:55 PM
errolmorris's Avatar
New Member
Default malfunctioning engine light
my ownwers manual is a bit thin on info for my 96 a4's engine light. has anyone had any experience with what the problem could be?
the light stays on after start-up
Old Apr 8, 2003 | 08:17 PM
AudiMick's Avatar
Default If it's the check engine light (MIL) Could be anything
You need to get the code read. It's usually something with emissions.If it starts to flash you need to stop driving ASAP as you will damage the CAT. Most common reason is bad or cheap 87 octane gas or a loose gas cap. However with a car this old (I have the same year) could be many things depending on the mileage. You could buy the shareware VAG.com tool from OBDtool.com. Cheaper than a trip to the dealer.Then at least if you can't fix it yourself you will be able to find out cost of repair. There are probably people on this forum in your area who will diagnose this for you for a beer. Post a message on the forum looking for a VAG.com
Old Apr 9, 2003 | 05:30 AM
mistral150's Avatar
New Member
Default If it stays on, you might dammage some engine part
the cat for instance. get it looked at sooner than later.
ta least that's what the 2001 manual says.
slib22
Audi allroad
Feb 24, 2006 12:20 PM
Chargin_Falls_A4
Dec 5, 2005 07:00 AM
Egil A64.2s - S6
Oct 13, 2003 05:09 PM
Stauden01
Oct 8, 2003 04:09 PM
S4 in NC
Apr 23, 2002 01:07 PM
