Manual Boost Controller
Old Nov 16, 2003 | 02:40 PM
The Burnt Audi's Avatar
Junior Member
Default Manual Boost Controller
So one the local tuners sugested that I try a MBC on my car. (Piggie from Audiworld) I just wasn't seeing the kind of boost that I should have with the hardware thats on my car EVO FMIC, EVO intake, GHL exhaust, GIAC chip, Stock K03. I was spiking at 14 psi and holding 12.5 psi and on a cold day it would drop off even more.
So to make a long story short. I got my boost back and then some. Right now I have it set so I spike AT 21 PSI and hold 16 PSI...I still need to play with it a little I will probably back it off a little...but right now the car is faster than it ever has been.
Here's where I got it www.joepmbc.com I would suggest this mod to anyone that wants a nice little tweak.
It's set up basically like this. But I'm using it to get more boost rather than control spikes.<ul><li><a href="http://www.audizine.com/forum/topic.asp?TOPIC_ID=34026&amp;FORUM_ID=73&amp;CAT_I D=3&amp;Topic_Title=How+to+Control+spikes+on+any+c hip+with+a+MBC%2E%2E%2E&amp;Forum_Title=2%2E+B5+S4 %2FRS4%20%20%20%20%20">http://www.audizine.com/forum/
Old Nov 16, 2003 | 02:43 PM
Zed 2.0's Avatar
Default just curious, but why would you avoid an obvious problem with your car by forcing it to boost more?
I mean, if you've already got a chip and all that and you're not making the right boost, something is wrong. Why fix that by forcing your car to do something it doesn't want?
Old Nov 16, 2003 | 02:48 PM
[ej257]'s Avatar
Member
Default Like Chup said, I would correct the problem the right way, and while the MBC
"fixes" the low boost, it doesn't fix what was really causing the low boost. Food for thought.
Old Nov 16, 2003 | 02:49 PM
Junior Member
It was more of a pressure drop problem...because of the FMIC...not because of a leak or bad BPV.
Old Nov 16, 2003 | 02:53 PM
qfrog Ti20's Avatar
Default MANUEL !!! where are you manuel ???
MANUAL.... M A N U A L
what the fvck is manuel?
Old Nov 16, 2003 | 02:56 PM
Audi2ptzero's Avatar
Elder Member
Default Even with the boost loss from the FMIC your still moving the same amount of air flow.
Now your just over working that small ndbw K03 even more, your also going to be hurting midrange power since the MBC cant control the wastegate like the N75 valve can.
Old Nov 16, 2003 | 02:58 PM
Junior Member
Jeez dude I fixed it sorry I got that 1 word wrong...maybe you would like to spell check the rest.
Old Nov 16, 2003 | 03:01 PM
Junior Member
Default Re: Even with the boost loss from the FMIC your still moving the same amount of air flow.
Hurt my midrange power...nope if anything it smooths everything out and I actually have more power all the way thru the power band.
 Michael S. Palmer
Old Nov 16, 2003 | 03:08 PM
Elder Member
Default Why dont you do some real logs with a vag and maybe you will understand.
Just so you understand. When you turn the boost up, the turbo spools much quicker causing the tq/hp power bands to move much lower in the rpms. This causes both the tq/hp to peak much sooner and then end up dropping off at a much faster rate.
Old Nov 16, 2003 | 03:15 PM
4Rings::G2 boosted::'s Avatar
Banned
&lt;homer&gt;It's pronounced nucular&lt;/homer&gt;
