MBC problem
Old Mar 29, 2005 | 06:45 PM
Brilliant_A4_99's Avatar
New Member
Default MBC problem
I have a '99 1.8t and I just recently installed a MBC on it. In first gear at full throttle it seems to be working fine, giving me a little more than 11 psi of boost. But after first gear it seems to be running stock boost at about 7 or 6. What could the problem be??
Old Mar 29, 2005 | 06:48 PM
mAd1(gt3071r)'s Avatar
Member
what did you do with the n75?
rookie18's Avatar
Default You will find that most people around here don't run MBC.
Why not get a chip?
Old Mar 29, 2005 | 06:49 PM
New Member
Default Re: what did you do with the n75?
I took an extra hose and connected the two openings together.. I read somewhere that you were supposed to do that, is that wrong?
Old Mar 29, 2005 | 06:51 PM
New Member
Default Re: You will find that most people around here don't run MBC.
Im only 16 and a little short on money : (
TristanP's Avatar
Default The problem is you're running an MBC
Chip that bad boy.
Old Mar 29, 2005 | 06:52 PM
TristanP's Avatar
Then wait until you can save the cash and do it right
Old Mar 29, 2005 | 06:54 PM
New Member
Default Re: Then wait until you can save the cash and do it right
what chip is the best? and how much is it?
 Michael S. Palmer
Old Mar 29, 2005 | 06:59 PM
Member
Default no not wrong
you recirculate the n75 so it doesn't throw any codes. Not to mention, it'll act real stupid if left open.
What turbo are you running btw? And the reason your not boosting that well is most likly due to programming. You can run an MBC all you want but if you don't have proper provisioning (software) for it, the MBC will just do harm. For example, can over heat the turbo, can cause the wastegate to stick. You have to be careful with an MBC. What's your current setup?
Old Mar 29, 2005 | 07:05 PM
TristanP's Avatar
Default You really want to do a search before asking that question
Used chips should be ~$300, but can vary. I got my spare ECU AND chip for $300. Check the classifieds.
