Modifying air filter
Old Dec 10, 1998 | 03:08 PM
Dmak
Guest
Posts: n/a
Default Modifying air filter
Anyone try to use a cone filter instead of OEM box? I believe TAP has one, but I think I can modify the box to accomodate a cone filter with a horn inside or even a cold air setup... Anyone have any thought of this? I think it will be possible to gain a 1-2 Hp from this setup.. <p>Dmak 1.8TQMS
Old Dec 10, 1998 | 03:13 PM
wc
Guest
Posts: n/a
Default Re: Modifying air filter
is a 1-2 hp gain worth the time and effort
Old Dec 10, 1998 | 03:20 PM
Steve S.
Guest
Posts: n/a
Default I know of two people
Edmund Louie had it on his car and took it off..I would contact him for details as to why. Lyle Ferguson also does. I do not suggest it without changing the ducting system on the car. It can increase the temperature of the air entering the engine...hence robbing the car of the extra horsepower you are trying to get. Remember your car wants cool air to breathe..not hot.<p>Steve S.<br>97 2.8QM<br>"Air Filters Will Travel"
Old Dec 10, 1998 | 03:56 PM
Jorge
Guest
Posts: n/a
Why spend the time to modify the intake box. Just buy a K & N drop in air filter or RAM air filter. They work just fine!<p>
Old Dec 10, 1998 | 07:40 PM
George Rochford
Guest
Posts: n/a
Default heat
Just wondering: Wouldn't our intercooler take care of any overly heated air that goes into the engine. Also, isn't the intake air just going to be super heated anyway by our red hot turbos, cone or no cone? I could see on a normally aspirated car how a cone would loose horsepower but on a turbo and intercooled car I would think the difference in intake temp wouldn't make much difference. What am I missing?<p>Faithfully,<br>George<br>97 1.8TqAS TAPII<br>94 911 Carrera 4
Old Dec 10, 1998 | 08:12 PM
Steve S.
Guest
Posts: n/a
Default Haven't you noticed how...
Haven't you noticed in really hot weather that the car is just not going very fast. I am definitely no expert in how turbos work, but I thought it had to do with hot...(and probably damp) air adversely affecting the turbos effectiveness. Hey, why doesn't one of our turboheads chime in here?...I am outta my league.<p>Normally Aspirated Steve<br>97 2.8QM<br>
Old Dec 10, 1998 | 09:31 PM
Edmund L
Guest
Posts: n/a
OK, once forum-god Steve mentions my name, i am oblidged to respond. . . *heh heh*. <p>Well, once i give you my experiences with the cones and induction systems of the sort, let me remind you that i have a 2.8 (30V) and i'm sure results will vary between that and your engine, the 4-banger. That being said. .. <p><A HREF="http://www.geocities.com/motorcity/speedway/8138" TARGET="_top">go to my webpage by clicking on this line.</A><p>There's a good amount of info there that i've compiled about my various experiences with the A4 - i haven't updated it in awhile, but it definently has stuff as well as pics on the intake cone i did. <p>NOW, onto my assessment of cone filters now that i've tried everything under the sun....the K&N cone added more power at 3000 rpm+. It definently had a bit more "grab and go" kinda feel to it, especially in 2nd and 3rd over the stock paper setup. However, part throttle and low rpm situations would go to the stock airbox - the fact that the cone grabs slightly hotter air (about 20-30F hotter) and what i term "a lack of air reserve" makes the off-idle response sluggish with the cone. See, i have a feeling that with the airbox the car has a larger volume of filtered air available to it, hence giving it better part-throttle response, over a cone which is just 3" piping into the throttle body. <p>I just popped in the K&N panel filter a couple days ago. . . i know this sounds retarded, but i think there is a difference. Off-idle isn't much different, but starting around 2800, it feels like the car goes a little bit more. . .accompinied by a little more induction noise. Oh, let me go off on a tangent here...the cone is LOUD in the car. VERY LOUD. It's cool, lots of people thought i had an exhaust on the car just by the way it sounded. But anyways....the car feels a bit peppier all around, and, unlike the cone, i don't have to suffer from lackster off-idle response (which is magnified during the summer, when the car is baking). <p>However, with ALL this being said, it could be different for turbos, so i'll shut up now. . . but i feel that i've given a reasonable account on how it goes for the 30V. .. <p>HTH, <br>Edmund Louie<br>98 A4Q 30V
Old Dec 11, 1998 | 06:11 AM
MT atl
Guest
Posts: n/a
Absolutely correct, Steve! All you suck is hot air with a cone and hot air &quot;not good&quot; for turbo performance! Turbos like realy cool dense air!
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 11, 1998 | 06:12 AM
MT atl
Guest
Posts: n/a
Stick with apanel filter, just go to a performance filter. I use K&amp;N, but there are others.
Pileits
Q5/SQ5 MKI (8R) Discussion
24
Apr 8, 2017 08:36 PM
RallyAudi
Jun 21, 2011 06:49 AM
ron717
A4 (B7 Platform) Discussion
Jul 28, 2008 04:35 AM
CRATOS
Sep 8, 2006 11:32 PM
CusTTom "Quag" WesTT
15
Apr 24, 2004 06:49 PM
